Buyer's guide CUPRA Born Buyer's Guide
Overview​
The CUPRA Born is CUPRA’s first fully electric model, launched in 2021 and based on the Volkswagen Group’s MEB platform. It shares underpinnings with the VW ID.3 but has sportier styling, a sharper chassis setup, and more driver-focused tuning. In 2025, the Born received updates, including more power for higher trims, improved infotainment, and greater range from its latest battery packs.
Key Specs at a Glance​
  • Body style: 5-door electric hatchback
  • Boot space: 385 litres
  • Batteries & power outputs (original launch):
    • 58 kWh – 204 PS (rear-wheel drive)
    • 58 kWh – 231 PS e-Boost (rear-wheel drive)
    • 77 kWh – 231 PS e-Boost (rear-wheel drive, larger range)
  • 2025 facelift/updates:
    • More powerful versions introduced, up to 326 PS (with dual-motor option rumoured in development)
    • Improved software and infotainment with a larger 12.9″ screen
    • Range extended to around 340–350 miles WLTP on larger battery versions
  • 0–62 mph: 6.6s (231 PS e-Boost 58 kWh) → quicker with new 2025 versions
  • Charging:
    • AC: up to 11 kW
    • DC: up to 170 kW (58 kWh), up to 200 kW (77 kWh facelift)
    • 5–80% in as little as 30 minutes on a 150 kW+ charger
Trim Levels​
  • V1 – entry spec, LED headlights, digital cockpit, 18" alloys
  • V2 – adds heated seats, larger wheels, rear-view camera
  • V3 – 20" alloys, upgraded seats (Dinamica bucket seats), head-up display
  • e-Boost pack – available on V2 and V3, adds sportier tuning and more power
  • Facelift/updates (2025) – streamlined trims, Black Edition styling packs, bigger screen standard on higher trims
Pros​
  • Distinctive styling compared with VW ID.3
  • Sharper handling with optional Dynamic Chassis Control
  • Good range, especially with 77 kWh battery
  • Strong equipment levels, even in V1 trim
  • 2025 update boosts power and tech to keep it competitive
Cons​
  • Boot space is smaller than rivals like the Tesla Model 3
  • The infotainment system can still feel laggy despite updates
  • Ride can be firm on larger wheels
Used Buyer’s Guide: What to Look Out For​
From owner reports on our CUPRA Born Forum, here are the main things to check when buying used:
Common Issues Reported by Owners​
  • Software bugs – infotainment freezes, slow navigation loading; check the car has had the latest over-the-air or dealer updates
  • Charging faults – ensure both AC and DC charging work properly; test with a rapid charger if possible
  • 12V battery drain – some owners report issues if the car is left parked for extended periods
  • Interior squeaks and rattles – particularly around trim and dash on early builds
  • Tyre wear – strong torque can wear rear tyres quickly, especially with e-Boost models
  • Heat pump option – worth checking if fitted, as it improves efficiency in cold weather
Buying Tips​
  • Prefer cars with a full service record and evidence of software updates
  • Check that charging cables (standard and rapid) are present and undamaged
  • Inspect tyres for even wear — alignment issues have been reported on some cars
  • Test drive to confirm smooth regenerative braking operation
  • Battery warranty: 8 years / 100,000 miles to 70% capacity — confirm coverage remains
Verdict​
The CUPRA Born is one of the most engaging compact EVs on sale, offering distinctive design and sharper handling than its VW sibling. Earlier cars already offer substantial value on the used market, and the 2025 updates enhance their appeal with more power, a longer range, and improved technology. For the best ownership experience, choose a car with a full update history and, if possible, the larger 77 kWh battery for range confidence.
Extra information and resources​
Author
Views
3,071
First release
Last update
More resources from Syphon
