I have listed below in DTC Number order all the DTC Blogs that OBD11 Have so far created and I am updating with links to VCDS WIKI for same code.
I have also added in the Toyota and BMW Codes (although some of these are shared with VAG as well)
For a full list of the VCDS DTC Wiki entries use this link
For a full list of the OBD2 DTC Site use this link you will need to schroll down to the bottom of the article for the full list.
Overview
P0011 – Intake camshaft timing over-advanced (bank 1)
VCDS WIKI
P0012 – Intake camshaft timing over-retarded (bank 1)
VCDS WIKI
P0014 – "B" camshaft timing over-advanced or performance issue. Bank 1
VCDS WIKI
P0016 – Crankshaft & camshaft misalignment (bank 1 sensor “A”)
VCDS WIKI
P0017 – Crankshaft & camshaft misalignment (bank 1 sensor “B”)
VCDS WIKI
P0101 – Mass or volume air flow "A" circuit range/performance
VCDS WIKI
P0102 – Mass or volume air flow "A" Circuit Low
VCDS WIKI
P0113– Intake air temperature sensor 1 circuit high input
VCDS WIKI
P0125 – Insufficient coolant temperature for closed loop fuel control
VCDS WIKI
P0128 – Coolant temperature below thermostat regulating temperature
Mechanic Base
P0135 – Oxygen sensor heater circuit malfunction (bank 1, sensor 1)
Mechanic Base
P0141 – Oxygen sensor heater circuit malfunction (bank 1, sensor 2
VCDS WIKI
P0171 – Fuel trim. System too lean. Bank 1
VCDS WIKI
P0172 – Fuel trim. System too rich (bank 1)
VCDS WIKI
P0174 – Fuel trim. System too lean. Bank 2
VCDS WIKI
P0299 – Turbocharger/Supercharger underboost condition
VCDS WIKI
P0300 – Random/Multiple cylinder misfire detected
VCDS WIKI
P0301 – Cylinder #1 misfire detected
VCDS WIKI
P0302– Cylinder #2 misfire detected
VCDS WIKI
P0304 – Cylinder #4 misfire detected
VCDS WIKI
P0335 – Crankshaft position sensor "A" circuit malfunction
Engine Codes
P0340 – Camshaft position sensor circuit malfunction
VCDS WIKI
P0401 – Exhaust gas recirculation (EGR) flow insufficient detected
VCDS WIKI
P0420 – Catalyst system efficiency below threshold. Bank 1
VCDS WIKI
OBD11 - Toyota info
P0430 – Catalyst system efficiency below threshold. Bank 2
VCDS WIKI
OBD11 - Toyota info
P0440 – Evaporative emission control system malfunction
VCDS WIKI
P0441 – Evaporative emission control system incorrect purge flow
VCDS WIKI
P0442 – Evaporative emission control system small leak detected
VCDS WIKI
P0446 – Evaporative emission control system vent control circuit malfunction
Engine Codes
P0449 – Evaporative emission control system vent valve/solenoid circuit malfunction
Engine Codes
P0455 – Evaporative emission control system gross leak detected
VCDS WIKI
P0456 – Evaporative emission control system very small leak detected
VCDS WIKI
P0496 – Evaporative emission control system flow during a non-purge condition
Engine Codes
P0499 – Evaporative emission control system vent valve control circuit high
Engine Codes
P0500 – Vehicle speed sensor (VSS) Malfunction
Engine Codes
P0521 – Engine Oil Pressure Sensor/Switch Range/Performance
Engine Codes
P0562 – System voltage low
Engine Codes
P1014 – Valvetronic reference eccentric shaft sensor parity error
Engine Codes
P1030, P1017 – Valvetronic system: No adjustment possible
Please note the details of this DTC are at the bottom of the page
P112F – Air mass system
P1176 – Heated catalyst power switch overtemperature condition bank 1
The document states this is a BMW Specific code but it is listed on the VCDS Wiki Page as well
P1290 – Electric wastegate, adaptation: Cold start not learned
P1447 – DMTL, system fault: pump current reaches limit value during valve test
P1449 – DMTL, system fault: Pump current too high during reference measurement
P1632 – Throttle valve adaptation conditions not met
P2000 – NOX trap efficiency below threshold. Bank 1
P2004 - Intake manifold runner control solenoid stuck open. Bank 1
VCDS WIKI
P2121 – Throttle/Pedal position sensor/switch "D" circuit range/performance
P287B00 Shift Fork Calibration Not Learned
P3000 – HV battery malfunction
U0073 – Control module communication bus
Overview
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
Mechanic Base
Mechanic Base
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
VCDS WIKI
Engine Codes
VCDS WIKI
VCDS WIKI
VCDS WIKI
OBD11 - Toyota info
VCDS WIKI
OBD11 - Toyota info
VCDS WIKI
VCDS WIKI
VCDS WIKI
Engine Codes
Engine Codes
VCDS WIKI
VCDS WIKI
Engine Codes
Engine Codes
Engine Codes
Engine Codes
Engine Codes
Engine Codes
VCDS WIKI
