| Work Required | At Millage | Additional Notes |
| 6-gear DSG gearbox 0D9: change the oil and filter | Every 60,000 km 37,300 Miles | |
| Panorama roof: check operation, clean drains and lubricate guides | After 3 years / max 60,000 km and then every 2 years or 60,000 km after that. | |
| Engine Oil Filter | Flexible oil change interval then every 18,641 miles / 30,000 km or 2 years Fixed oil change interval, Maximum every 9320 miles / 15,000 km or once a year | |
| Air Filter | Every 55923 miles / 90,000 km or 6 years | |
| Dust and Pollen Filter | Every 37282 miles / 60,000 km or 2 years | |
| Oil Change Service | PR QI1 - every 5,000km PR QI2 – every 7,500km PR QI3 – every 10,000 km PR QI4 – every 15,000 km PR Q17 – every 30,000 km | |
| Spark Plugs | Every 37,282 miles / 60,000 km or 4 years | |
| Front axle differential lock oil change | Every 3 years | Please note many main dealers don’t deal with cupra’s and do not understand about the front diff, this needs to be looked after. |
| Brake fluid and clutch: Renew | After 3 years (first time) and then every 2 years | |
| Key Fob Battery | When warning message shown on the screen | CR2032 Battery. How to video can be found here |
Taken from the Revo vehicle-care-maintenance
Care and general maintenance are important for any vehicle regardless of the state of tune. The further you push your vehicle the more you need to service it. Below are some recommendations for servicing and maintenance.
Recommended
For a stage 1 or 2 vehicles, Revo suggests that you maintain the same service schedule recommended by your vehicle’s manufacturer. Unlike standard air-filters that you replace aftermarket air-filters required routine cleaning in order to correctly function, this needs to be accounted for with your general servicing.
For stage 2+ and higher stage vehicles, Revo highly recommends reducing the service intervals. As you are running more power through the engine, wear is obviously going to increase.
Vehicle use-age has a big effect on general wear and tear. If you use your vehicle on the track or for long distance driving trips; it’s advised to do both pre and post inspection and fluid changes.
