The next phase.....
caveo
Right guys most of you know my spec ( if you dont click my link ) and in august ( when i get back from hol ) im adding a spec stage 3 clutch and single mass fly wheel , a Quaife diff and some eibach ARB's.:D:D
My question is how much will these affect the drive and feel of the car and will the clutch,fw and diff improve my 0-60 time?
Also i may be able to squeeze another grand out of the missis so what else should i get done ( i was thinking a racing inlet and cone filter??) whats your guys thoughts???:think:
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Honestly when my car would be understeering on full lock going straight on, his was just turning and turning and turning ... it felt like it would never run out of grip, I was quite concerned on the first roundabout we went at ( knowing how my own car handles) and i've got all the rest of the suspension bits and bobs done. For somewhere that has a lot of roundabouts it would be a tidy mod to have.
caveo
Well worksop bypass has 5 huge roundabouts all seperated by almost perfect 1/4 mile carageways.... Its my playground and i rule with an iron fist!
caveo
Was thinking bout breaks but id need bigger wheels as i have 17's. Also cocidered rods,pistons and rebore to 1.9 but was quoted 2300 notes .
So its all up in the air , decisions decisions!!!!
caveo
EBC ultimax disks with greenstuff pads , so not much better lol
caveo
The only way to do that is to increase disk size and that means bigger wheels so i would be looking at 2 grand ish so no go.
D.K
LCR 225
Oct 24, 2007
6,309
se london
I'd do the breaks mate.
Seems a bit daft haveing all that power and not being able to stop it espicially if your talking about adding more power
caveo
Mine only just clear the oe calipers so owt worth doing would meen 18's.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,917
sunny sussex
or crashing? and daft spending everything you have mate only to get out braked at every corner....
whatever the cost brakes/suspension and tyres... absolute must for bt.
UncleFester
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Having driven around on standard brakes and then on 312mm upgraded discs on a phase 1 remapped diesel ... the 4pot porsche calipers I have now I would consider to be the minimum required. I would not care to run the power you're running without having sorted the brakes first.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,917
sunny sussex
it could be used as a wonderful excuse to stick thicker alloys on too. i only went half inch wider but helped grip loads. little more torque steer and tramlining but worth it for the improvements. :)
