jamiebennett81
well I was driving home tonight when the clutch pedal started sticking
by this I mean when accelerating from 1st the clutch is staying pressed against the floor, which then to change to 2nd I have to flick the clutch pedal up so it goes back to its normal position and then change to 2nd and the same again to 3rd
gears 3rd - 6th seem to be fine and the clutch pedal does not stick
it is alot worse in reverse, the clutch pedal stays completely pressed down and the bite point is instant, making it very hard not to stall the car straight away
now when I had the clutch installed, Storm Developments commented that it possibly had a faulty clutch release bearing, due to excessive rattle
now I have a lightened flywheel, and when I phoned TTS roadsport they said this is normal for the "rattle". Since the car has been in 2 garages for tuning work to be done, both have commented that despite the lightened flywheel the sound is not normal and the bearing is faulty
despite the above, could it be the clutch cable? although in the lower gears the cable seems to be working fine, so it cant be this as I cant imagine this would cause the "stickiness" and for the pedal not to flick back into it's original position
your thoughts please, as I need to phone TTS tomorrow and get this sorted asap
and of all the times, I have been looking forward to showing the car at E38, and its very doubtful I will if the clutch is on its way out
