Guys,
The following code will give you welcome home lights etc every time you unlock /lock or open a door /hatch. This coding works as tested by me and I don't have auto lights.
Obviously all coding is done at your own risk
1 You must use the VCDS cable program and activate the following codes:
Change the value to: Interior Light so all the lights will work when the car has the door opened.
8.Leuchte23SL HLC10 Lichtfunktion C23
8.Leuchte24SL HRA65Lichtfunktion C24
5.Leuchte25KZL HA59 Lichtfunktion B25
8.Leuchte26NSL LA72 Lichtfunktion C26
8.Leuchte27NSL RC6Lichtfunktion C27
8.Leuchte2SL VLB10 Lichtfunktion C2
8.Leuchte 3SLVRB21 Lichtfunktion C3
5.Leuchte4TFL LB4 Lichtfunktion B4
5.Leuchte5TFL RB32 Lichtfunktion B5
12.Leuchte6ABL LC5 Lichtfunktion E6
12.Leuchte7ABL RB1 Lichtfunktion E7
