00771 - Fuel Level Sensor (G): Open / Short Circuit to B+ advise please
aletchet
51
advise please
My fuel guage is displaying 0 - nothing.
i turned off the car and it seemed to display properly see it when i put the key in. started it again and then after a few seconds it went back to 0.
did a scan with the vagcom and got :
so looked this up:
Possible Symptoms
Fuel reserve displayed value 0 (empty)
Possible Causes
Wiring between Fuel Level Sensor (G) and Instrument Cluster: Open or Short Circuit
Possible Solutions
Check wiring between Fuel Level Sensor (G) and Instrument Cluster
Check Measuring Block Value
Where is the fuel level sensor ?
and how do i "check the measuring block value" ?
doubt the wiring is just going to fall over randomly, so presume maybe the unit has become faulty and ill need to change it? does the tank need to be dropped and drained for this ?
or is this an easy DIY job ?
i knew something else would go, been something every 2 months so far..
lovely
thanks
Ant
towcester vag
1,775
duston northants
probably the sender in tank
you can get to them without taking tank out but needs to be below 3/4 full
unbolt the big plate 3 screws
then unbolt the sender/pump assy top to gain access
aletchet
51
incidentally has started working again now.. i think something is obviously not quite tight if moving the car around has put it back in place.
excuse my ignorance, big plate 3 screws ? do i need to access this from the underside of the car, or is this somewhere under the back seats?
