Feb 16, 2013
1,102
North Wales
strange thing happened on the way home from my road trip yesterday,i noticed that the wipers were on it wipes ok but a few secs later its soaking again then inside starts misting up on this side only?
the aircon only removes this misting up only not any heating
so the outside keeps getting wet which then causes the inside to mist up,wheres it coming from?
the things ive done lately
taken off the sound proofing under bonnet to check for leaks,now this is saggier than before
cleaned down the wiper arms and under the bonnet latches cos they were caked in leaves and crud
had the fmic and revo intake changed
any thoughts on this guys its doing my head in grrr
cheers
simon
lol not today m8 as its not rained yet
i did drive in the thunder storm though with the wipers on full speed and my cold air feed probably took in some rain haha
i taken off the bonnet insulation also and noticed it was wet at the front also so im just wondering if that was the cause?
I had to keep blowing really warm air then really cold. Then it eventually nestled out at like 19c on the climate. It was a nightmare.
again this problem has arised grrr:cry:
went for a meal and came back to the car with the whole of the inside of the windscreen misted up?
sat there with the heating on hi with no luck so stuck the aircon on just to clear it enough to drive 10 minutes later
i turned the aircon off half way home for the passenger side to start misting up again,:confused:i cant be doing with this everytime i wanna go out in the cold weather:censored:
any suggestions please?
ive put a ebay pollen filter in it beginning of the year,maybe its not good enough or not fitted well?
cheers
strange thing happened on the way home from my road trip yesterday,i noticed that the wipers were on it wipes ok but a few secs later its soaking again (probably because water was falling from the sky) then inside starts misting up on this side only?
the aircon only removes this misting up (if it's removing the misting then surely it's working?) only not any heating (have you got your blowers set to windscreen only and on recirculation? Turn both you climate settings to hot/HI )
so the outside keeps getting wet which then causes the inside to mist up,wheres it coming from? (Again the sky search Google for evaporation)
taken off the sound proofing under bonnet to check for leaks,(why would the bonnet leak? ) now this is saggier than before
cheers
simon
:(:rolleyes:
Edited with no sarcasm for you!
