Stephen O
516
Manchester
Has anyone changed their glow plug's on 2.0 tdi engine? Is it a pain of a job, im assuming they are under the rocker cover.
Glow plug change
Have you high mileage , bad starting or failed glow plugs on it?
The last 2.0TDI that I replaced 4 months back had 130K on it and they never needed replacing. I believe from memory the service book may show you at what mileage that they are recommended to be replaced but i'm sure that is when it reaches a fair chunk of miles.
If it's poor starting only in very cold weather I'd be inclined to check the battery first before going anywhere near the glow plugs.
Glow Plugs
From memory i am sure the recommended replacement of a battery is 4-5 year old.
Think you may also need to consider the cold weather conditions ref. diesel temperature etc.
for me I would be doing battery first, diesel filter cartridge (as a matter of change), maybe check starter motor (under load) then glow plugs.....
