34k,Leon FR DPF light on, limp mode HELP!
connartiste
Hi spent the last while having look through all the info on DPF lights and problems and still feel a bit in the dark! Wonder if anyone can help me!
Had the DPF light come on late yesterday and didn't know what it was and seein it was the last mile of a 60 mile journey thought i would just leave it till the morning. Started the car today and the light was still there, rwlaised what it was and tried giving it a bit of a blast to get the DPF heated up. Then the coil light came on and the car went into "limp mode". I drove it conservatively home and I am now wondering if I can sort this without a trip to the dealer!
Thanks!
ajc
Mine did exactly the same thing and i took it to the dealer and they charged me £150 for a sensor on the dpf. They said they gave me discount but it soulds like you need to take it to the garage and see if they can give it the re gen and try to clear it out first failing that you might have the same problem as i had. If its still under warrenty you might get it done foc but you will have to ask them cos they wont tell you. Good luck.
connartiste
Thanks mate i'm proably gonna phone a few places tomorrow and see what they say but failing that i'll take it back to the seat garage i got it. Sounds like a lot of problmes with these DPFs!
ajc
Ive started using V power diesel and never had a problem since. Dont know if its a coincidence or not. :)
FR_Flavoured
Sounds quite similar to what I've experienced plus others.
As per the Post by ajc above - mine was not the DPF filter at fault, but the DPF Pressure Sensor.
The sensor was replaced by SEAT dealer, plus DPF Regen carried out - all ok after that.
Hope your issue is just minor too, best drive carefully - just to be on the safe side, until you can get it fixed. ;)
If you want to do the job yourself, you might need to connect your car up to one of the VAG COM diagnostic system available, which should give you an indication of the specific errors/codes being reported - then you might decide if you can do the job yourself.
A more direct alternative, is to do away with the DPF filter altogether, search for "DPF Delete" here on the boards. But then unless you go with one of the recommended "Tuners", you could end up with a different set of problems. :)
fr_jay
122
exact same problem as i had mate just told dealer i wanted new dpf and didnt want it clearing
luckily mines under warranty
fr_jay
122
well when i biught the car i had nothing but probs for 3 months and that was the last straw for me i told em i wasnt happy customer service was shite and i didnt want the car back until its fully working i even have the invoice of how much it cost which was 1593 to be exact for the dpf and fitting
WeeG
3,407
Largs , Ayrshire
Thanks!
The sensors are a piece of piss to change mate, you will get a sensor from a local dealer (Bickets Kilmarnock) for under £100. :)
Going by the details you have given it sounds like a sensor has blown
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
When you think about the DPF temps that can be reached (I have seen 700 degrees with VAG-COM) it's no surprise that they melt being screwed into the DPF really.
connartiste
took the leon to my local garage ive used for years and they stuck it thru the diagnostic for no charge :) error code theyve came back with was "08194 P2002 Particulate trap bank n1: efficienty below thresdold".
The fella at the garage agrees its a sensor but is unsure which one, would my googling and researching be right in saying that this is definelty a fault in the exhaust pressure sensor? I take it the sensor is attached to the DPF? Also, excuse the barrage of questions, if the sensor is replaced, how can i get the car out its limp mode, will vag com or equivalent be needed?
WeeG
3,407
Largs , Ayrshire
Once you install the new sensor, you will have to reset the fault code which if you have chosen the right sensor will clear the fault code and bringthe car back to normal :) To reset you can use vagcom or any other car diagnostic reader
OLDOILER
1,292
Wiltshire, UK
Thanks!
There was a problem with one of the sensor's in the early days, which should have been sorted under warranty [ problem right across the VAG group 56 - 58 plates] you dont say what year your car is -PD I assume?? mine failed just after a service on the ramps!! and was fixed FOC. Im sure if you search on here you should find the answer has to which sensor it was . .................................
dee_b
limp mode
ive had the same problem with mine same scenario one minute dpf light next thing dash looking like a chritmas tree and in limp mode , its a 56 plate fairly high mileage tdi fr , been advised i need a new dpf filter and f**k me they aint cheap £1200 for the filter and £300 for the regeneration , ive been told because of the high mileage the dpf needs changing , is there any other solutions is the sensor advisable please help
connartiste
All sorted! as suspected, was a dodgy sensor! Got a new sensor fitted, forced regen and a cpu update and the cars running like a dream! Spent ages researching the fault and phoning various places but ended up taking it back to the Seat garage i got it and they were pretty reasonable. Got the car back after about 2 hours and it had even been washed and hoovered. I've seen the sensor myself and it would be pretty easy to fit a new one at home but unless you've got your own software you wont be able to get it out of limp mode without a forced regen.
