ABS fault *moved*
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
mainly a couple of sensors packin up or damaged ? but nothing on ABS pumps at the moment ?
why whats up , recall ? or just a fault on yours ?
SGP_Toledo
My ABS is working fine. depends how hard u slam the brakes.
EnthusiasmBoy
The ABS seems a little eager on my car. Feels like it cuts in too soon. Can it be adjusted at all?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
probably a foam soled shoe would help :D
nah seriously , itll cut in on drain covers etc , BUT if its cutting in on gentle braking get it in to be checked , we have done 2 V5's that have had warped discs although it was vibration as a fault , may well be the first signs ????
andycalvia
339
53
39
Ayrshire
yeh anything like braking on wet leaves, going over drain covers or anything that has tittle grip will trigger the ABS its quite simple to check, try braking on a fairly empty dual carraigeway late at night in the dry and see what happens!
SWANSWAY CUPRA Dealership
