AC 230V plug retrofit. Is it possible?
Feb 19, 2020
7
Good idea but no. I have several things which I can´t charge via USB port (DSRL, Mavic Drone), I saw 230V plug in Golf 7 or Skoda Octavia 3 /Superb 3, so I thought it could be possible to retrofit it into Leon
marlop
This is from a Leon Mk4. Sure it could be retrofitted into a Mk3.
Feb 19, 2020
7
Well, I know about it, but I want OEM solution.
Odesláno z mého SM-G965F pomocí Tapatalk
billman
120
19
You don't need 230V to charge your mavic, you can use the car charger. If you want 230V though you will need an inverter hidden somewhere in the car and have it hardwired. The outlet that you will see depends on your preference and obviously you can install whichever you like. What do you mean by OEM solution? Was there any Leon with 230V outlet socket from the factory?
Feb 19, 2020
7
I know, but. It´s approx 50€ for Mavic charger, there is another approx 50-100€ for charger for DSLR. That´s why I want original inverter. Beucase I don´t need to buy several chargers for each device of if I buy another device (Mavic have several charges for each device, there is no universal car chager for all devices)
