Jul 12, 2021
7
I have a 2021 Seat Leon SE Dynamic and wondering if it has Adaptive Cruise Control or just standard Cruise control
Hi, Would imagine its just standard cruise, its not available on any SE cars, only available as an option on fr and above and standard on xcellance lux models, would be able to tell on the steering wheel as well, hope that helps?
Sent from my SM-N986B using Tapatalk
Thanks, yeah I've just looked at the steering wheel of a lux and it has the distance button on it mine doesn't. I was just wondering as when I turned my cruise control on the other day it came up as Adaptive Cruise Control so was just wondering.
Have you a radar in the grille under the front number plate? Looks like a flat square
Yes when I select limiter in the menu and go back to cruise control and then activate it, it comes up as Adaptive Cruise Control (ACC)
And yes I have a black square below the numberplate
The front radar is also used for front collision assist and is standard on all models. It's likely your seeing adaptive cruise control as a software bug with the car.
If you haven't got the distance button on the steering wheel then you don't have adaptive cruise control. Another way to tell is in the driver assist menu in car settings, one option should be adaptive cruise control
