Anyone running a digital dash?
I'm running the polar FIS advanced PF03 unit on my dash (v0.5.2 firmware)...
And more to the point, does anyone know where the CAN gateway module (J533) is located on the Mk2 Facelift Leon?
I had a poke around above the pedals where the BCM module (J519) is located but I can see no sign of the CAN gateway module.
On the Golf Mk VI it is up above the pedals (see this video) but there is no sign of it in the same place on my car. Keep in mind that my car is right-hand drive and the video is a left-hand drive car. Maybe the CAN gateway is up under the passenger side footwell on a right-hand drive car (somewhere behind the glove compartment) but I haven't looked yet as it means stripping off some trim for that. Does anyone know?
As promised, below are pictures showing the location of the CAN Bus Gateway (J533) on a RHD Mk2 SEAT Leon. You can see the red CAN Bus plug sticking out the top of it.Anyway, the good news is that after some more poking around this morning I finally found the CAN bus gateway module (J533) in my car but the bad news is that it's in a absolute nightmare location to access. I need to go out now so I'll post up some pictures later, but if you pull off the trim cover that hides the OBD port (to the right of the steering wheel under the headlight switch panel) then shine a torch in there, you can just about see the J533 module with a red plug sticking out the top of it right at the back behind all the wires and relays.
To install the polarFIS unit on your car, you can inspire from this tutorial on mk6 golf RHD
pretty much the same think![]()
