AL Cupra
Have a FL 10 Reg Cupra only done 3800 miles on it.
Started the car tonight and the air con didn't blown at all. Just at a time when the weather has changed & I need it most because the windscreen keeps misting up and I cant see a thing.
The lights move on on the dash system (eg turning fan or temperature changes) and I can here a noise when I choose which direction the air should blow in (eg windscreen, face, feet) so it sounds like the mechanism for the direction seems to work. However there is no air blowing whatsoever on any setting (hot/cold/light/strong).
I can't tell if its a blown fuse as its pitch black outside plus the last time I looked at a car fuse box it was simple board with cylindrical fuses, mine seems to have big square boxes of various sizes all over the place and I can't tell which is which (I aint good with car maintenance
I'm sure it will be fixed under warranty but I bet as usual my garage cant get my a courtesy car for about 3 weeks and so I could be stuck for a while.
Has anyone else had a problem with their air con units so early and if so what was the fix???
