GregLCR04
99 Ron Please!!!!
Oct 31, 2006
115
Dumbarton, Scotland
Hi folks, need some info if possible, have tried searching to no avail!
The alarm doesn't seem to be working on my LCR. Indicators flash but no alarm sound:confused:
Any ideas??
The chirp can be turned on via vag com, if that is what you mean.
Leave a window down a set the alarm see if it goes off when yo put your arm inside the open window.
Lee its not the alarm chirp mate, I don't have that. Its just the alarm sound, its as though it goes off but, indicators continually flash but no alarm:confused:.
Was reading a thread about exactly this on Briskoda about an Octavia.
First of all, check the LED in the door -- if the alarm system is OK, it will flash rapidly for a couple of seconds and then settle down to a regular flash after switching the alarm on. If there is a fault, then the LED flashes rapidly for 2 seconds, stays on constant for 30 seconds, and then goes into the slow flash mode.
Secondly, get a scan with VAGCOM -- if the alarm siren is down, you'll probably get a fault code stating that there is no communication between the siren and the alarm
This indicates a faulty siren, and in the case of the Octavia, is around £90 from the dealer to replace.
Mike
