G60Steve
I recently bought a 1998 Alhambra 1.9TDi with no reverse gear.I'm hoping for a "quick fix" but knowing my luck it will be a box off or replacement box scenario.
Anyway can anyone shed any light on this problem or had similar symptoms?
All 5 forward gears select as they should do but when trying to select reverse it just will not go into the "gate".It moves across ok but it's solid when trying to bring it back down to select reverse.
The box is a DBW code one.....and do any other gear boxes fit from the VAG range...just in case i need a replacement?
Any help much appreciated.
