alteadriver
Evening,
We have a 2004 Altea with a tailgate that refuses to open, have to go through the back seats now and fart about with the fiddly manual release now.
I have already had to put a folded flap of duck tape over the worn micro switch, that works perfectly.
Now, after temporarily giving up while we were on holiday in August the release will not work at all.
I have replaced the solenoid/latch assembly and checked the micro switch - I can hear that clicking when I lift the tailgate handle. The release worked for a few days after replacing the latch but I think that was just luck!
So I took the car to a local auto electrician who says the car needs a new convenience unit, about £300 + VAT, plus fitting!
The VAG COM printout they gave me has this on it:
00950 - Central Locking Motor - Tailgate (V53); UNLOCK
0007 - Short to Ground
The wires going to the plug connected to the solenoid are damaged, (after having a wheelchair in the boot that only just fitted) the electrician seems to think that may have caused a short circuit.
Do you guys have any ideas what else could be causing the problem? I'd rather not have to replace the convenience unit, if it is unavoidable I think I'll try Sere Motors for a better price.
Thanks,
Mark
Thanks,
Mark
