Altea TDI 140: spluttering, black smoke, disconnecting MAF fixes it. Not turbo!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Been away from the forum for a long time. Redundancy, job searching and etc proved to take a lot of time and sap confidence, leaving me not in a good place. Now I have a problem and hope someone here can help.
Altea TDI 140 Sport, BKD engine, 130K miles. Good service history, no previous engine problems.
On the way home from the last of several recent visits to the North East from Kent, sorting out my newly-deceased father's estate, house and belongings (another story, maybe later) the car lost power, stuttering and putting out black smoke. Was able to get home (carried on for 100 miles or so) but all is not well.
Removing connection to MAF cures stuttering and black smoke. Without MAF connected, engine is down on power, struggles to reach 4000 rpm when under way, but is otherwise polite, does not choke following motorists.
Put it in to local independent VAG specialist. They say the MAF signals are good, but turbo actuator not holding vacuum. Diagnosis is 'turbo problem', but they (quite reasonably) don't rebuild turbos and the VAG fix for this car is 'replace turbo'. Not able to afford > £1K at this point.
Tried replacing turbo actuator (not a simple task) setting rod length to match the one we took out. Somewhat better response but still stutters and puts out black smoke. Removing MAF connection still has the same effect, stops the black smoke and reduces power output.
My hope is that someone here recognises the symptoms and ca either cofirm it is a turbo failure of some kind or can identify what else might be at issue. It's confounding me.
Will also post in TDI section, to try to catch all possible answers. Forgive me for double-posting this once?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Update: A second investigation by a local garage/service center/whathaveyou has found a hole in the intercooler. This would fit the symptoms pretty well - when the turbo goes you usually know all about it. So, fingers crossed that that is all it is. Will soon know.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Intercooler replaced and new seals all round. No smoke, no stuttering, boost is back to what I expect. Have hit limp mode a couple of times. I suspect the turbo and maybe the cat are a bit sooty, I will try to get the turbo nice and hot and see if it improves things.
minimarvel
38
ESSEX UK
Your experience sounds relevant to every diesel owner. Thanks for sharing and good luck with everything.
SeatJay
293
Sounds very similar to mine when it had an overboost issue. Would recommend getting some turbo cleaner through it.
Hope your back to work now and sorry to hear about your father!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Some further remedial work needed, so I took it back to the guys who diagnosed and replaced the intercooler: it turns out that when we replaced the actuator, we set the rod length by counting threads, and did not notice that the rods themselves were of different lengths... Embarrassing error, and it accounts for the overboost in no uncertain terms.
Rod reset to correct length (by comparing it with the original, which we still had), and a little tuning done to match boost demand to boost delivered.
My goodness, what a difference. Not only am I now a good citizen, leaving no black sooty trails, the power delivery is better than it was before the work, and the fuel economy is notably better too, on short runs something like 5mpg better. Not done a long run yet, but it all looks very good.
So, probably two faults, the leaky actuator (which may be due to age, or the strain of dealing with the holed intercooler, or both) and the intercooler itself. What seems to have happened there is that one of the square-section tubes has failed along one edge, which is where they are weakest of course. I suppose that they flex a little when containing boost.
So all is well again. Except now I have to investigate why the mirrors have stopped working. I suspect the switch, but it's not a simple matter to get the console off so I can have a look at it. And its not just a simple set of contacts, no, there's resistors in there too. Never a dull moment.
