any ideas?
sionowz
230
cardiff
Any ideas as to hoe to get the blookin sump plug off? so far a hammer and spanner have failed! The car is on stands as i write![:@]
Dec 17, 2006
1,837
Bristol
If you haven't got the sump plug out, you can always drop the car back down if you need to get some more tools?
Just wondering if the wheel nut iron is the same size as the sump plug bolt? Worth a try?
sionowz
230
cardiff
that was my though...i checked and it wasnt there!! floomin typical. Ive put engine flush in the car...would i damage it if i drove with it in?
woody1986
mad as a box of frogs
Oct 21, 2008
106
Derbyshire
u can drive with engine flush in for up to two hours in my experiance, this also gives the flush chance to circulated around your engine to loosen up crap!!
have you tried slightly heating the plug as this makes the metal a bit more supple and loosens its grip making it easier to turn!!
woody1986
Oct 21, 2008
106
Derbyshire
sorry is it engine oil flush? If so dont use your car for driving till you have drained and replaced your oil.
If its coolant flush then you can use your car normally for a few hours.
woody1986
Oct 21, 2008
106
Derbyshire
no i wouldnt. i assumed u ment coolant flush as iv just dne my coolant recently soz fella.
if your bolt rounds off too much u could use a pair of pipe grips to get ot out then replace it with a new bolt! (assuming it comes loose!!)
sionowz
230
cardiff
Job done. £70 later.....!! Breaker bar...blow torch..cold chisel...breaker bar and impact socket then off it comes!!! :)
GtiBoy
DubbedOut Owner
May 5, 2009
326
Botswana
www.dubbedoutclub.tk
I fully feel for ya mate as i had this problem on my old beezer i dint get it off full stop lol and in my current ibiza i ended up smacking myself in the lip wiv a socket and it didnt stop bleeding for 4 hours plus i cudnt eat proply for days lmao
