Anybody have a ''coolant flow diagram?''
ibiza_95
1.8T MK2 Conversion
its the best i could describe it as :p
like a diagram for the 1.8 20VT that shows the flow of coolant around the engine and through the different pipes...
ive seen one before on tinterweb somewhere but ive been searching for ages and cannot find it again :(
Thank you please :)
cuprachrissy
this si the only one i have, hope its of somee help mate
1 - Breather pipe
q From gravity valve on fuel tank
2 - Activated charcoal filter
q With solenoid valve 1 for activated charcoal filter -N80-
3 - Turbocharger
4 - Pressure unit
q For charge pressure control valve
5 - Non-return valve
q For activated charcoal filter system
6 - Charge pressure regulation solenoid valve -N75-
q The valve will be activated from the engine control unit (pulsed)
7 - Non-return valve
q For brake servo
8 - Crankcase breather pressure regulating valve
9 - Brake servo
10 - Air cleaner with air mass meter (-G70-)
11 - Overrun shut-off valve
q Checking → Chapter
12 - Charge pressure sender -G31- charge air cooler
13 - Combi-valve
q For secondary air system
14 - Fuel pressure regulator
15 - Non-return valve
16 - Turbocharger divert valve -N249-
17 - Crankcase breather
18 - Secondary air pump motor (-V101-) */**
19 - Non-return valve
20 - Vacuum reservoir
21 - Secondary air inlet valve -N112-
