Thinking about changing the gearbox oil over the holidays for something to do. I'm happy with which oil it requires but is the drain and refill itself the usual 'drain and the refill 'til it starts coming out the fill hole' stuff? TIA.
Hello there,
Mr Paddy6789 uploaded workshop manuals in PDF format for the
Leon MK3 (
Leon MK3 official SEAT workshop manuals link)
They're in the
resources section his post is on page 5 I think.
Paddy6789 has uploaded other manuals for electronics, steering, suspension, bodywork, brakes, all for the
MK3 Leon.
I've had a quick read of the manual files for the 6 speed boxes, one is the 02S gearbox which is file D4B802C0B70
pages 186 and 239.
This box is manual transmission 6 speed, states that regarding gear oil change you can't really use the oil filler hole, as the tilt of engine/gearbox is at a slight angle, resulting in normal gear oil level sitting lower then the lower part of threads in oil filler hole, so it'll be over filled if you go by oil trickle from filler level hole.
The manual states with the 02S gearbox it can only be refilled correctly, if the old oil is drained into a 3 litre measuring jug/bucket, to ensure you refill correct amount with new oil.
This is because of the tilt the running gear sits at which makes the normal oil level sit much lower than the oil filler level plug hole, according to the PDF manual.
Regarding the gear oil capacity for this 02S box, all the manual states is the following = if gearbox has been fully striped down and fully rebuilt, use 2.3 litres of gear oil.
If gearbox has partly been striped and repaired, use 2.1 litres of gear oil.
That's all the manual says regarding refilling with new oil.
So I think 2.0 litres max for a gear oil change, anymore and it'll be overfilled according to the manual. And it can't run/trickle out of the oil filler level plug hole, the normal level has to be under/lower then the oil filler level hole, for correct healthy running of gearbox.
To refill the PDF manual says can remove reverse light switch at box selector tower, but I would have thought you can refill via the filler plug hole, depending on excess as running gear is at a tilt so might be gearbox mount in the way ??
02S gearbox codes
MK3 Leon:
NBJ, QSZ, QXH, RSW,
1.4 TSI with 147 bhp
RMH, TJW,
1.5 TSI engine 147 bhp
NBH, QBN, QWZ, RSN,
1.8 TSI engine 180 bhp
PTW, QVX, RSD,
1.6 TDI engine 108 bhp
The other gearbox is the 0AJ box which again is manual transmission 6 speed,
but this box you are ok to check & refill using the oil filler level hole, as the running gear sits more level according to the PDF manual.
This PDF manual file is D4B802C0BA3
pages 145 and 146
0AJ gearbox codes
MK3 Leon:
MUF, PRL,
1.2 TSI engine 103 bhp & 1.4 TSI with 123 bhp
QGG, REK, SEE,
1.0 TSI engine 114 bhp
SEH,
RGB,
1.2 TSI engine 108 bhp & 1.4 TSI with 123 bhp
SEL,
1.5 TSI engine 129 to 134 bhp
Oil filler plug / oil drain plug that are female multipoint hex plugs, torque setting is 25 Nm (18.4 ft-Ib)
Single female hex filler / drain plugs, torque setting is 30 Nm (22.1 ft-Ib)
Hope this helps
Si
