Boc starting then cutting out
Cocozza06
Hi all,
Not long had my boc but went to go out to it this morning and it would turn over and start but would cut out straight away there is fuel etc and oil etc is all fine and when plugging into a diagnostic there are no errors codes?
Also when driving the car the tyre pressure warning guage come on alone with the traction control like turning the traction off don't have a clue why as all tyre pressures were fine
Anyone able to give me some advise please?
Anything would help thank you
skyrocketeer
Asphalt pilot
Feb 1, 2016
92
7
Newport S.Wales
tyre pressure monitoring is done by measuring the roadwheel speeds relative to each other - so the fact you have tpms and traction control lights coming on suggest possibly an issue with an ABS sensor
Cocozza06
Hi all just an update
Had it pulled into all sorts of machines, no communication from ecu as if it is locked! checked all wiring it is fine, showing up fault codes but not letting me read them! Guessing only thing to do is to get it into seat dealership
