Bonnet release cable
Leighton267
11
Had to purchase a new bonnet catch and cable but forgot where the cable goes in to the car from the latch to connect it to the leaver any help ?
bruceR
2,568
664
Monifieth, Dundee
Drivers side way up under the dash, never had to fit one but would think it might be easier pushing it through the grommet from the engine bay into the cat - hopefully someone will have a write-up
Leighton267
11
I know where it’s supposed to go out at the bottom for the handle but I can’t remember where in the engine bay it goes in haha
bruceR
2,568
664
Monifieth, Dundee
Here’s a pic of mine from engine bay but looks like you’ll need to lift up or remove the scuttle plate
Gokiwi64
Geriatric Member
Apr 26, 2014
1,370
715
Hockley, Essex
Once it goes under the scuttle panel it goes into a black rubber grommet (the source of many a leak) adjacent to the largew electrical connector (another source of many a leak).
Leighton267
11
So I’ve managed to get the cable back into the rubber grommet but cannot seem to find it in the inside of the car ?
bruceR
2,568
664
Monifieth, Dundee
You might be better if you remove the lower dash trim and loosen the fuse holder - this should give a bit more room
