Broken headlight clips
duncagr
hi all,
the plastic fixig clips on my drivers headlight snapped when i was "fixing" something. so now its loose and pointing at the ground!
i cant find a replacement anywhere as mine is a gti so has twin bulbs so im wondering if my only bet is the stealers!?!?
happened the week i planned to fit the hids too, :(
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
Daft idea and i know is bodging,but if you have all the clips super glue them back on,but do a few coats and make sure u fill all the holes and gaps!
duncagr
ye, tried that and it worked for a while, bt never as strong as before!! and one clips lost so im stuck!!!
ibiza_streg
221
Cornwall
The two bottom clips on mine a slightly snapped but I managed to bodge it together. You really need the top one to secure it properly....
You could do what I did with my fog lights when the clip snapped off that. Get a piece of metal with two holes in it and screw one into the plastic and the other hole can be a replacment for the original mounting hole thing. Worth a try if its possible.
Your best bet is to email all the breakers on ebay and see if they have one, I suspect a new one from the dealer would be rather expensive....
