Hi all,
I’ve got a 2009 3 door Ibiza 6j.
I took the car to get the wheel alignment done as it was pulling to the left, and although the garage managed to get the toe straitened up the camber on the left passenger side is out by a nearly two degrees.
He said that the camber cannot he adjusted on the front so he said the subframe may have moved which maybe causing it to be out so he went away and after an hour the camber was still the same.
He theory is the car may have hit a kerb that side or pot hole quite badly causing it to be out so he suggested changing the lower control arms on both sides and the suspension legs, as if these has a kink in it would cause the camber to be out.
I’ve had the lower control arms changed and the car is still pulling to the left. Do I spend more money changing the suspension legs? For it to still pull to the left? Can the camber be adjusted up front?!?! Without having to do all this work?
I’m at a crossroads.
The car has never been in an accident by the way.
