Can't adjust Headlight Beam Levels!
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
Well I just got back from a car shop that helped me to fix my HID kits. I realised that it needs some adjustment. But I can only adjust the right hand side of the carlamp (via from engine) and also the motor level from inside the car. Thing is, the left side doesn't. Even the internal adjustment doesn't work. How do I know if my headlight on the leftside's can be adjusted? I think it's quite dangerous for the oncoming traffics as the light beams are set too high.
Is there any alternatives that I could adjust it from elsewhere? I dont mind if the motor level's not working. ... Well it'll be better though if I can fix it too!
ALIII.CZ
If it doesn't work from inside the car, try it manually with the srew on the back side of the left carlamp. If it doesn't work as well, you'll have to buy a new lamp maybe? :eek:(
