Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
hi
i have a mk3 ibiza chill and want to put a cd player into it. it has the climate control radio fitting in it with the lcd screen. any help on how i can do it?????? ta
hi, and welcome to the site. keep an eye out in the for sale section for a 6 disk multi changer or ebay, it fits on the passenger side iner arch in the boot. if you pull back the arch carpet or maybe remove the spare wheel carpet you should find a random blue plug on the passenger side there somewhere and thats the multi changer plug, plug in and away you go
Quite a few people (including myself) have fitted a stereo underneath the steering wheel. Only did this because the oem stereo was playing up. The 6cd changer in the boot is the easiest option.
hi
Im new to this if you do what you said find the cable in the boot and put a 6 cd changer to it ?? does this enable you to put speakers and a sub in thanks
you would have to run new cable from hu to the boot for amp an sub, you could join speaker wire to your original speaker cable if you want 6x9s in ur parcelshelf.
there is a how toguide on installing a sub and amp, have a search
im not sure but i dont see why not, peel back the passenger side boot lining, the cable comes from the back seats direction so may be tucked right up in there but its there, jus have to have a good hunt around
