CupraJoe1984
So, last week everything went off, interior lights, electric windows and mirrors and central locking, found the solution to most things one of small fuses were blown now everything working again apart from central locking, little light at top of drivers door does not flash when locked with key, also only drivers door will lock/unlock with keyall other doors need to be locked via the button on drivers door which still locks/unlocks them all, any ideas? I've checked all the fuses now in the drivers side box but they all ok, is there a fuse somewhere I'm missing?, where is the pump located on the cupra?. Cheers. Joe
There a central locking box up under the right hand side of the steering wheel mate in behind the fuse box it would have 2 plugs going into it..That would give problems.But the driver's side front window motor also controls the locking 2.
So judging by what I've said do you have any kind of hunch as to where to start looking?
mine stopped working when i had a alarm fitted turned out the fuse had gone same as yours and the 2 looms for the locking had been disturbed unplugged and replugged them in and been spot on since so worth a look they are sat behind the fuse box as stated before
