Changing Brake light
muzzy00_uk
Hi all
Just a quick and easy one on sure.
Ive just been told my offside brake light has gone. I was just wondering is it pretty easy to replace?
I asume i have to either get to or remove the rear light cluster to replace it. Hopefully thats it but wanted to double check.
Muzzy
andycupra
status subject to change
can you change a bulb?
open boot.
on the offside pull away the part of the trim thats behind the light cluster. (there is a bit cut out just for this)
then it should be fairly obvious what to do to change the bulb.
***see post #4 for pics :)***
muzzy00_uk
erm... 'brake' light? ;)
open boot.
lol if its that easy that would explain why i couldnt find anything using the search. Thanks andy!! Im glad its not gonna be difficult, even for me!! :p
andycupra
Here you go some pics.
The light is split into two sections per side. - One section is lights and indicator, the other which is in the boot itself is brake reverse and fog i think).
This photo shows the recess inside the boot for access to the rear offside indicator and rear light.
(trim has been removed for photo, no tools needed).
The red arrows indicate where the clips are that keep the bulb holders in place. Simply push these towards the middle to release. The second pic shows the bulb holder released.
To replace, simply push back in, the clips will hold it.
This photo shows the recess inside the boot itself (the bit that actually opens) for access to the offside brake, reverse and i think fog light.
muzzy00_uk
ok..... ive just taken a look and i feel really stupid now. sorry for the really stupid question.
Thank you for your help Andy! :D
DeeroTDI
50
Just changed my brake/tail light bulb in my Mk1 as someone told me my brake light was out. Seem to have developed a front brake light too- ie the front sidelight now lights up when I press the brake pedal!
Any ideas?!
