Coilover help
steve7786
78
8
Spray some good penetrating fluid on the top mount nuts. Up through the wheel arch. Both of my front top mounts had 1 bolt that ripped the nut out of the mount. A right royal pain in the arris to sort. Do the front, then the rear. No need to have the whole car jacked up. Rears are easy enough to do. I'd look at new top mounts and if they go like mine it's the only option for you.
Reactions: Sharpy
Legojon
I only wanted a remap
5,084
2,540
As above. I definitely replace the top mounts if I had the suspension in pieces. Also, I haven't done Leon struts... but all I've done previously are that annoying bolt you have to hold with a spanner while you use a hex key to round off the inner hex. If it's that type I 100% recommend getting an electric rattle gun. I got the Silverline one for £50 and it's save me so many headaches.
Reactions: Sharpy
