Hi would anyone be able to advise me on a few things ?
1. Does the
cupra 300 Leon dsg 6spd have a timing belt or chain and when does it need to be changed ?
2. How much it likely to cost and is it worth changing the water pump at the same time ?
It's done 31k miles
Timing chain, you need regular good quality regular oil changes to keep it in good order.
The water pump housing (plastic) may give
up, causing a leak, unfortunately it's quite common on these engines. Just keep an eye on coolant level.
The cost of the water pump/thermostat fix is appx £475 from a main dealer.
My car is in at the moment for investigation for this fault.
Hope this helps
