Cupra r driveshaft torque setting for hex bolt answered
19jeff89
67
Hi im new on here, but i have done the usual searching for a few hours but cant find a definate answer on torque setting
I have a 2004 Cupra r bam engine 02m gearbox im changing the nearside driveshaft i think im right in saying the bolts to the gearbox are 10nm (nipped up) then 70nm but cant find a proper answer for the hub bolt hex not 12 point.
if anyone knows of the top of there head would be muchly apreciated
thanks
rang seat today and got torque setting
use new bolt best to pop center cap out of wheel and put wheel on
tighten to 240 nm of the floor with 2nd person with foot on brake
lower car so wheel is on the floor but not all the way
tighten a further 90 degrees
slacken bolt 90 degrees
lift car back up so wheel is of the floor
slacken a further 90 degrees
tighten again at 240nm
lower the car so wheel is on the floor but not all the way
finally tighten 90 degrees
this procedure is because its a stretch bolt
wheels are 120nm also
s1 evoloution
95
drive shafts M10 70nm or 52lb FT
HUB NUT
STAGE 1 200NM or 148lb ft
stage 2 slacken nut one full turn (360 degrees)
stage 3 50 nm or 37 lb ft
stage 4 angle -tighten 60 degrees (equal to 2 points on 12 point nut OR for
HUB BOLT
stage 1 240nm or 177 lb ft
stage 2 angle tighten a further 90. degrees
stage 3 slacken bolt by one half turn (180 degrees)
stage 4 240 nm or 177 lb ft
final stage angle tighten a further 90 degreees
These are haynes manual settings for audi a3 petrol turbo and diesel turbo
19jeff89
67
hi thanks for replying could you confirm if thats for 12 point hub bolt or hex hub bolt?
i have auto data books but only mentions 12 point hub bolt
thanks
