How do I go about doing the data logging on vag-com to get the performance figures like bhp, torque and boost pressure??
Where do I go and what do I need to do??
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Chris...
You need to log the following groups:
002 - MAF
115 - Boost
120 - Torque
I hope that helps.
Scott
Thanks Scott.
How is the best way to log. Drive in each gear and log the data around to the redline??
I do have a spread sheet that will do the conversion into bhp, lb/ft and psi etc.
Log 003, 118, 115,020, 031, and 032
Do no more than 2 at a time to get any reasonable samples.
003 and 020, then 115 and 031, then 118 and 032.
This gives you, airflow, actual timing, timing pull, requested boost, actual boost, target air fuel, actual airfuel, n75 duty, inlet temp, actual boost, and then finally fuel trims.
Thanks for your help on this guys. I did a log on my mates LC and we got some results, don't know if they are any good though.
Also converted the data into the spread sheet that I have and we got our own power graph.
dont suppose youd forward them to me would you please Rob?You can download some from the Ross-Tech site or make them yourself. I did both.
