Apr 7, 2022
Is there a way to disable the beeping that happens when closing the sliding doors on a 2014 Alhambra? Alternatively (as the beep as probably a necessary safety feature with the electric/automatic closing), is there a way to just set the sliding doors to manual? Pulling hard when opening seems to go to manual mode, but I've not worked out how to do a manual close and avoid the beeping (which is disturbing neighbours).
I wonder if this is like other Seat cars where the beep can only be enabled/disabled using an OBD device (Such as Carista, OBDEleven).
Thanks CW92, you might be right it might need setting through an OBD device - defo doesn't appear to be anything in the user settings menus.
Reactions: CW92
Will be like the Ateca electric tailgate.
https://www.seatcupra.net/forums/th...rking-ones-for-the-ateca.438134/#post-4723100
You need a bit of German to navigate around the parameters. Nate a Dutch expect German speaker found that one at the time. It was sitting in the central electronics. You searched under a key word in German.... that's assuming it works that way.
T6 / T5 they say not a software fix and they physically disconnect it:
Suspect its similar. Tailgate they say software control Vcds / Obdeleven etc whilst side doors has to be physical.
