All FR models get 'sport' suspension as standard, which really just means it's set up a bit stiffer than the 'comfort' suspension in the SE model. Previously, only models with 180ps or above got the rear multilink, and I'd be very surprised if that changed for the 1.4ACT. I certainly haven't heard otherwise yet!
In everyday use there is so little between them. You have to be really pushing on to tell any real difference between an FR with, and one without the multilink. It's nice to have, but you certainly wouldn't feel hard done by without it. Unless you are related to a rally driver!
On the FR at least the multilink has a smoother ride, noticeably less harsh. Otherwise the difference is minimal bar the 180/184 brakes having a bit more bite in them.All FR models get 'sport' suspension as standard, which really just means it's set up a bit stiffer than the 'comfort' suspension in the SE model. Previously, only models with 180ps or above got the rear multilink, and I'd be very surprised if that changed for the 1.4ACT. I certainly haven't heard otherwise yet!
There is the added advantage that should the rear tyres start to wear unevenly, the multilink suspension will be adjustable, were as the standard suspension probably wont be.
