martincloud9
I have a Cupra TDI150. A short while ago it started making a knocking noise from the engine. I have worked on cars alot before and thought it sounded like a big end bearing playing up. It is always there, but gets worse with revving and engine heating up. It is a deep knock and does not sound like the tappets and is a lot slower than a tappet click. It is a constant knock as though it is going with the crank. I had the Dual mass flywheel changed as it was worn (apparently). No good. I had the big ends checked. No joy. Now costing a fortune with no luck.
Can anyone here help me out before I have to remortgage the house. I have only had this car for 8 weeks and the 'warranty' doesn't cover wear and tear!!
I also had a suspension coil snap the day before this happened. Not alot of joy with the Cupra so far!!!
