Exhaust Rattle at certain revs
Monkriss
Okay so i got my car in september. In February the exaust started to rattle at 1.9k revs and 3.5k revs. I went to the garage and they said the centre silencer is breaking up so they fit a new one.
A week later the problem was still there. they said it was the centre silencer. so they replaced it for free because it had only lasted a week.
I had no problems until about 3 weeks ago (4 months since last silencer) when it started to rattle at those revs. so i thought, must be the centre silencer again?
I replace the centre silencer and the problem went. now 1 week has passed and would you have guessed it. its rattleing again.
Makes me think, is it actually the silencer. and surely if it was breaking up, it would rattle no matter what revs it is. It must be some kind of resonating frequency at 1.9 and 3k revs.
What could be causing the rattle?? im tempted to remove the centre silencer completely and put a straight through pipe. but want some ideas first.
The rattle noise itself, it sounds like a hollow buzzing noise. and no my exaust isnt blowing. ive heard blowing and it sounds completely different
hope someone can help
Monkriss
oh and, inbetween the revs that causes the rattle. the exaust sounds fine and has no problems
Olly20VT
1,234
Stroud Glos ,England
A loose heat shield? Maybe it gets pushed back when you've changed the bits and then comes loose again after some driving, I would get under there and wiggle everything. I've had it on mine and my wifes A3
Monkriss
yeah i got that knocking problem too.. the exhaust slips on a rubber part and bangs against my car. very annoying but i cabletied it and it seems okay for now.
yeah might take it down to the garage today and ask if my heatshielding is loose cheers
chris1788
78
Dubai
mine rattled near centre silencer there is a metal plate that goes across and it rubbed on there, fitted few spacers to move away from exhaust problem solved
