flywheel clutch ?
cupra1.8t
leeroy
Nov 21, 2006
213
tamworth
just want some advise please chaps im taking my gearbox out to change the rear crank seal and thinking bout a g60 flywheel but not to sure wot i need any got a list i need to get do i have to change the clutch or not ? done a search but havent found wot i need ....
cheers
Feb 25, 2007
657
stroud
standard g60 flywheel but lightend and ballanced you will need the g60 bolts for the flywheel and you need a g60 corrado clutch kit with thrust bearing it works a treat JUST GET A CORRADO G60 CLUTCH KIT WHICH COMES WITH THRUST BEARING MY SACHS KIT COST £75.00 FROM MY LOCAL MOTOR FACTORS
roly
midnightmotors.net
Jan 2, 2002
1,883
Midnight Motors Workshop
i'll be putting a lightened 16v flywheel and vr6 clutch into mine in the next week or so
will let you know how im getting on once it's bedded in a bit
