Mancseat
42
I aquired a 1m2 Toledo 110 tdi that had been left in a field for 3 years allegedly.
Stupidly I didn't run a scan with VCDS before starting work. As it turns out the engine has been blocked by the immobiliser and the copy of VagTacho that I have has been unable to access the ECU to retrieve the Pin/SKU code.
Has anyone got any suggestions other than trailer/tow/transport it to a dealer or buy a plug and play/Immo defeated ECU ?
I'm about 6 miles from Honiton should there be anyone close capable of solving this issue. I'm certain I can resolve the mechanical issues. Not sure the best route to take on the programming front. Cheers in advance for any help.
Vag Commander 3.6 solved my immediate problem. The car starts and runs until switched off. Will update if anything changes
