Front door wont open
Lancashire_guy
29
Just purchased Seat Leon Fr and noticed this morning that the front passanger door wont open with key when the rest of the doors open
Any ideas?
Thank you in advance
reddbull87
11
I have same issue with mine. Apparently it's the latch and it's quite a common problem on these.
All doors lock from the remote, but the driver's will not unlock. It opens from inside as it should etc. It's just a bit embarrassing when you stand there in the rain :cartman:
What I found strange however is that after driving off the car locks itself. When you come to a stop and switch the engine off, put your window down and try to open the driver's door from outside, it works.
rocky
74
There's a common problem with the locking modules on these. Replace it with a working one
Sent from my SM-G900F using Tapatalk
CupraTOC
227
8
My passenger front door has caught this bug this week. Intermittent problem when unlock button pressed on fob, the outside handle will not open the door and it has to be opened from the inside. However, once the door is open you can close it and open it from the outside until you hit the lock button on the fob again and back to square one!
Can this be confirmed as the door module at fault ? If it is who knows the part number I need to fix this ?
