Front & Rear Brake Pads
queen
~Nassia~
Nov 29, 2010
723
82
Athens, Greece
My front pads are almost worn out so I'm gonna have to change them, and I was thinking of getting some yellowstuffs. The thing is I have the so called seat racing brakes with the 4pot calipers. Does anyone know the code for the pads I need?
Is this the right one? http://www.awesomegti.com/car/seat/ibiza6j/ebc-yellowstuff-front-brake-pads-ibiza-1-4-turbo-180-2009
Since I'll be changing the front pads with a new and improved set, I was thinking of changing the rear pads too, because the braking power will be even greater on the front and I wouldn't want to change the braking balance, so are these the right ones? http://www.awesomegti.com/car/seat/ibiza6j/ebc-yellowstuff-rear-brake-pads-ibiza-1-4-turbo-180-2009
Also, which brake fluid would you recommend?
Thank you!
May 4, 2009
524
Leeds
Thank you!
its more than likely that the above pads are to fit the standard non upgraded callipers.
you may also need to look into the fitting kit as apparently your meant to replace the pins along with the pads on the AP Callipers
queen
~Nassia~
Nov 29, 2010
723
82
Athens, Greece
Grant, you were right. The front ones are actually these: http://www.awesomegti.com/catalogsearch/result/?q=DP4036R
The rear ones remain the standard as the only difference is the painted red caliper.
One more thing though. I'm interested in this: http://www.awesomegti.com/car/vw/polo9n/superpro-lower-engine-steady-rear-bush-kit-ib-mk4-fabia-polo-9n-9n3-1-4tsi-ibiza-6j-fr-cupra-bocanegra-polo-6r-gti-fabia-5j-vrs-models
and I remember that it came in two levels of hardness road or track, now it's petrol or diesel, as I want to buy the hardest, could it be that the diesel is the track style one?
