I was wondering if anyone would know where to find new connectors/lines for the fuel supply/return lines between the tank and the filter.
I jumped under the car to change out the filter as the car has been losing power mid range under full load and throwing up a low fuel pressure code.
Anyway, when trying to reconnect the fitting for the return line to the filter, I found the o-rings and internals of the fitting to be mangled and my attempts to force it on had only made things worse.
With the car now parked up and immobile, does anyone know what part numbers I should be looking for in order to replace the two tank/filter lines?
Apologies for any mistakes. My hands are still frozenn after wrestling for ages with the filter and bracket.
While I'm at it, does anyone know if a new filter bracket is also available?
