Scousekidda
24
Can anybody tell me the location of the fuse for the front froglights please? I've looked on the image of the board layout and can't find reference to it.
There are no specific fuses for the fog lamps. If the Central Electronics Control Module (CECM) detects an over-current condition on the fog lamp circuit it will disable them (so it's essentially an electronically controlled trip-switch). If your fog lights aren't working and you've checked that the on/off switch is working OK then you need to get your car hooked up to a VAG diagnostics machine or VCDS to check for any fault codes on the CECM relating to the fog lamps. If any related fault codes are present then clearing them will reset the trip-switch.
