my fans used to work as should - slow speed with ac on and sometimes high speed if sat in traffic for ages, i used to reguraly check the slow speed fans because seeing how common the fault was. recently noticed the a/c cycling on the high speed fans only, and surprize surprize the no longer run on slow speed.
Before i go and order the fuses etc and repair them, am i right in thinking the high speed fans has a fuse on top of the battery....does the slow speed fans have a fuse there too?
im going to unplug the radiator thermoswitch and link the connections (as per video on youtube) to test the slow speed and high speed fans....but im fairly sure im going to have to do the resistor repair.
