I did this only a month ago. Its easy but i recommend that you buy longer bolts to help you compress the new bushes.
Jack up the car and take off the wheel on one side. Place a good support under the body (at the wishbone mount is a good place) of the car and let the jack down on it. Leave the standard jack in place also for added safety. Do you have a tolley jack? If so, jack up the wishbone to take the pressure off the anti-rollbar.
Remove the anti-rollbar bolt and remove the bracket surrounding the bush. A crow bar or big screwdriver can come in handy to lever the bracket. Also use the trolley jack up and down SLOWLY to release the bush if necessary.
Take note of the way the old bush is in place. Remove old bush and replace with new bush. Replace bracket - this can be tricky, Locate the catch at the bottom of the backet and push the bracket around the rubber bush the best you can by hand (a little fairy liquid can help it slide on)
The lug where the bolt goes through will be well away from the body and if you put in the origional bolts you will find they dont reach to start the tread. The easiest solution is to buy longer bolts. I changed them to 35mm long bolts(size M8). These will start on the tread and you can tighten them and pull in the bracket. Dont try taking them out to put in the origional bolts because the bracket will just spring open again.
Replace wheel and let down onto the ground again and repeat for the other side.
Takes about 45mins per bush.
Hope this helps
Hi,
Many thanks for the detailed guide. I thought it might be that simple but was not sure. I thought that the actual bar needed to come off to replace the bushes but this is not the case
I just changed mine today as they where SQUEAKING insane every time I hit other than perfect flat road surface. Original bushes looked new tho... weird.
Hi,
The bushes are split in like a c section so these wrap around the bar instead of slipping down the bar.
As said above its an easy job but getting the bolts in is a PITA but longer bolts would help big time
arb bush size
Hi guys I know bringin up old thread but was is the size of the arb on standard lcr 05 as im chamgin my ushes but I dnt know what size I need and cnt find it any where .. thanks
