lobs84
126
Coventry
Hi all,
I'm just wondering if all H7 bulbs are the same? I have just installed some white LED sidelight bulbs and they seem to put my Night breakers to shame. What i'm asking is, I have saw some LED H7 bulbs but they say that they are for fog lights. Would they be too bright for my dipped beam?
Regards
Will.
55W 4300k HIDS fitted
LED bulbs are unsuitable for headlamps for three reasons:
You can't get them bright enough (yet).
The individual LED's are very directional, emitting over a fairly narrow cone.
They take the form of a cluster of LED sources, so the light source is the wrong shape for the reflector. The beam pattern would be completely up the spout.
If and when a single LED is made that will put out the same light power as a 55W filament bulb it will need a completely different headlight design, probably some form of projector with a lens in front to widen and shape the beam.
The "bulbs" you linked to claim 450 lumens output. The chart here
http://www.danielsternlighting.com/tech/bulbs/bulb_types/bulb_types.html
shows that most car headlight bulbs fall in the 1000 - 1600 lumens area. 450 lumens will be impossibly dim.
They would work in foglights because -
a: Foglights produce an unfocussed, diffuse output, low and wide, not a focussed beam, so beam pattern is not important.
b: Foglights don't require high power, they are for finding the edges of the road/white lines when the fog is so dense that headlights produce a white wall of backscatter. 20mph weather. At best.
you all know that putting hids in a car that is not designed to use them ( as in came out of the factory with them fitted ) will be illegal come next april and will automatically be an mot failure.
