Hello all,
I found out that Leon hazard warning light button has a problem - when you pressed it, it stays pressed and could not be switched off. Button stays in completely fully pressed position (not in ON position), you have to use your own magic to be able to get it out of pressed position to position ON to be able to press it again to switch it off.
This is happening occasionally - but at least so frequently that even in SEAT service center where I came they already known about this problem.
I just want to inform you that SEAT will repair your hazard warning light button first time you visit SEAT service center, as this is worldwide action (up to my information)..
Repair means they will not change your button with a new one with correct function, but they will insert some kind of felt in the button area so the button will not stays in fully pressed position.
a FELT??
This was told to me in service...
a FELT??
