Head Gasket??
Cain_88
Sunday morning coming home from nightshift my car decided to overheat,
I stoped to check it out and looks to have lost some water from the bottle and the water looks like its darker..
I fear its tell tale signs of the head gaskets blown.
Roughly how much does this cost to fix?
and if I done it myself, what parts would I need exactly?
ive had the timing belt + tensioner done last year do I need to again then?
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
Head gasket set and get the head skimmed, not sure about cost for the head set as that varies a lot but a skim shouldn't be more than £40-£50. You might also need head bolts, I usually replace them as a matter of course but some can be reused.:)
STdemoniac
VAG-COM Grays, ESSEX
Jun 17, 2011
147
Grays, ESSEX
just make sure no oil in water system, if some oil there, then before opening head check a oil cooler ...
i have many time on VAG cars leaking oil cooler, ist no leak outside, but oil leak into water and block cooling system, engine temp. come high.... but if u on time find out this, can save head gasket...
don`t know what happen with u car, but maybe just oil cooler ??? :confused:
