May 12, 2017
8
Bristol
Hi guys,
Hoping someone has a suggestion as to the title post. Why are my brake lights on permanently!?
At first I thought it was potentially a simple fix with it being a faulty sensor/switch or something. This is not the case.
Garage (main dealer) have had my car for a week + still trying to identify the problem.
They did mention the possibility of it being a fault lying in the body control module or ECU.
Both of these have now definitely been ruled out after having both replaced and re-coded.
Literally losing my head over this!
Appreciate all suggestions/opinions.
Many thanks!
Anyone else able to help potentially diagnose this fault!?
Completely stuck at the moment.
This sounds ridiculous but I had this problem, it ran my battery flat. Once I got back home I realised my brake light was stuck on and this was draining the battery. I removed the fuse (the (break light went off) then put it back in and it's been fine ever since.
